How to Remote Control a PC From Any Device
Ryan CarterRyan Carter
2026-08-25
Learn how to remote control a PC from any device and access your computer remotely from anywhere with a simple remote access setup.
Remote computer control technology allows you to access and operate a computer without sitting right in front of it. Whether you are on a business trip, working remotely, or simply need to check files on your home computer, remote access capabilities enable you to control your machine using other devices.
This article introduces the concept of remote computer control, the requirements for getting started, and how to set up remote access using various devices.
What Does It Mean to Remote Control a PC?
Remote computer control refers to accessing and operating a computer via a network connection using another device. The remote computer continues to run at its original location, transmitting its screen display to the device you are using; simultaneously, your inputs—such as those from a keyboard, mouse, or touchscreen—are sent back to the remote computer.
This allows you to perform various tasks—such as launching applications, accessing files, changing settings, or using installed software—even when you are not physically present at the remote computer. However, the actual user experience depends on factors such as your network connection, the devices involved, and the remote access software being used.
What Do You Need to Remote Control a PC?
First, ensure that the computer you wish to control is powered on, connected to the internet, and configured to allow remote connections.
Additionally, you will need a second device to act as the connecting unit. Depending on the remote access software you choose, this device could be another Windows PC, a Mac, a laptop, a tablet, an Android phone, or an iPhone.
Both devices should maintain a stable internet connection. Connection quality affects the responsiveness of the remote session, particularly when using high-resolution displays, transferring large files, or running graphics-intensive applications.
Finally, you need remote access software capable of establishing a connection between the two devices. Some tools may require additional network configuration, while others are designed to simplify the process; choose the tool that best suits your needs.
Once these preparations are complete, you can begin setting up remote computer access.
Remote Control PC
How to Remote Control a PC From Another Device
There are various ways to remotely control a computer from another device over the internet. The best choice depends on the operating system you use, the location of the remote computer, and the level of setup you are willing to undertake.
Generally, you can choose between built-in remote access features and third-party remote desktop control tools. Built-in features often work well for users operating within a single ecosystem, whereas third-party tools typically offer broader cross-platform support and a simpler connection process.
1.Use Built-In Remote Access Options
Most mainstream operating systems offer their own remote access capabilities. These tools are highly practical if your devices are compatible and you only require basic remote control functions.
**Windows Remote Desktop (RDP) **is primarily designed for connecting to Windows PCs. It is particularly useful for users who wish to access a Windows PC from another compatible device, especially within a work or home network environment. Depending on your specific setup, accessing the PC from outside the local area network (LAN) may require additional configuration.
MacOS Screen Sharing feature enables remote access to compatible Mac computers. It is best suited for users within the Apple ecosystem who need to control a Mac using another supported device.
Chrome Remote Desktop operates via the web and supports multiple platforms including Windows, Mac, Linux and iOS. It is a convenient choice for users seeking a relatively simple way to access their computers without being tied to a single operating system.
While these built-in or platform-specific solutions generally meet basic remote access needs, specific features and setup procedures may vary depending on the devices and network environments involved.
remote control a PC
2.Use Third-Party Remote Desktop Software
Third-party remote access tools are highly useful when you need greater flexibility across different devices or systems, or when you wish to utilize advanced features beyond basic screen control.
For instance, AweSun supports Windows, macOS, Android, and iOS platforms, making it an excellent choice for users who want to remotely control a PC from another computer, laptop, tablet, or smartphone. It is suitable for a wide range of scenarios, including routine remote access, unattended access, file transfer, remote assistance, and multi-monitor workflows.
Other tools, such as Splashtop and RustDesk, also support cross-device remote desktop access and cater to diverse user needs. Some tools focus on remote work and business applications, while others are better suited for users who desire greater control over how their remote access environment is deployed.
Regardless of which third-party remote access tool you choose, the connection process is generally similar across the board and typically very straightforward.
3.Set Up the Remote Connection
While specific steps vary depending on the tool used, the general process is as follows:
1.Download and Install remote access software on both the computer you wish to control and the device used to initiate the connection. 2.Log in or configure the remote access feature on the host computer. 3.Ensure the remote computer remains powered on and connected to the internet. 4.Open the remote access application on the other device and select the computer you wish to control. 5.Start the remote session to operate the computer using a keyboard, mouse, or touchscreen.
Taking AweSun as an example, you can connect by entering the remote device's ID and password, or—for more convenient access—link the devices to the same AweRay account.
Once the connection is established, you can access the remote desktop and perform various tasks based on the tool's capabilities. These tasks include viewing files via a mobile phone, using a laptop to access software on the remote computer, providing remote assistance, or collaborating across multiple monitors. You even can play PC games remotely using AweSun software.
Consequently, the primary differences between various remote access methods lie not in the basic operational workflow, but in factors such as supported device types, frame rates, and the additional features available during the remote session.
remote control PC remotely
Best Practices for Secure Remote PC Control
The ability to access your computer from anywhere also means that security must be integrated into the setup process.
The following basic practices help ensure the security of your remote computer access:
-Set a strong, unique password for your remote access account. -Enable additional authentication methods whenever possible. -Keep your remote access software and operating system up to date. -Authorize only devices you trust. -Terminate the connection session when it is no longer needed. -Avoid accessing sensitive information over insecure public networks. -Use remote control tools that feature secure encryption.
Selecting the appropriate level of access permissions is also crucial. If the other party only needs to resolve a temporary technical issue, a one-time remote assistance session is generally more appropriate than granting permanent, unattended access.
Remote control functionality is most effective when it integrates seamlessly into your existing device usage habits. Whether you occasionally need to view files on your phone or frequently require remote access to a desktop computer located elsewhere, the key lies in choosing a solution that supports your current devices while meeting your specific performance and access needs.
If you are looking to connect across major platforms without the hassle of establishing separate workflows for different devices, AweSun offers an ideal, practical solution that enables you to access and control your computer remotely—anytime, anywhere.
Can I control my computer remotely using my mobile phone?
Yes. It is recommended to use compatible remote access software that allows you to connect to your computer from an Android or iOS device, view the screen, and interact with the computer using touch controls.
Can I control my Windows PC from a Mac?
Some tools allow you to do this. It is best to choose cross-platform remote access software—such as AweSun—that enables you to connect to a Windows computer from a Mac.
Do I need to configure port forwarding to remote control a PC?
Not necessarily. While some remote access methods may require additional network configuration, dedicated remote access software—such as Awesun—can typically establish a connection without manual port forwarding.
Can I remotely control a PC when nobody is there?
Yes. You can do this by enabling unattended access, as long as the PC is powered on, connected to the internet, and configured to accept remote connections.
How can I turn on a computer remotely?
Some remote access tools support remote startup, though certain ones may require complex configuration. If you aren't very familiar with computer software, you can use AweSun in conjunction with its Q1 hardware to power on your computer remotely.
Ryan Carter
Ryan CarterSystems Automation
