Do you need to access your home or office computer while connected to a different Wi-Fi network or internet connection?
Whether you're traveling for work, retrieving a file, or checking something on another PC, remote access can let you control a computer over the internet.
This guide explains how remote access works across different network environments, the available control methods, and how to establish a remote session.
Remote Access on the Same Network vs. a Different Network
Remote access is possible whether the two devices are connected to the same network or located on different networks, though the method of establishing the connection may differ slightly.
Accessing a Computer on the Same Network
Remote access is generally simpler when two devices are connected to the same local area network (such as a shared home or office Wi-Fi network). Computers on the same network can communicate directly, and some remote desktop solutions even allow connections using the computer's local IP address or hostname.
Accessing a Computer on a Different Network
Unlike devices on the same local network, computers on different networks cannot usually communicate with each other directly. The remote connection therefore has to be established through the internet, using a method that allows the two devices to locate and communicate with each other.
The required setup depends largely on the remote access method you choose.
Remote Access Methods for Different Networks
When two computers are connected to different networks, the method used to establish a connection may vary. Is there a universal solution that works in every scenario?
Remote Desktop Software
For most users, remote desktop software is the simplest option. Once installed and configured, it allows devices to connect over the Internet—often without requiring manual network setup. It serves as a versatile solution suitable for a wide range of scenarios.
VPN-Based Access
A VPN allows a remote device to connect to a private network as if it were physically connected to that network. This option is highly useful for accessing multiple network resources but may require additional configuration.
Port Forwarding
Port forwarding directs incoming Internet traffic to a specific device within a private network. While it works with certain remote desktop configurations, it typically requires modifying router and firewall settings.
Which Method Should You Choose?
For most users' remote access scenarios, using remote desktop software is the simplest way to get started, as it eliminates many of the network configuration steps typically required by other methods. The following steps outline the standard setup process.
How to Remote Access a Computer on a Different Network
Once the remote access method has been selected, the next step is to prepare the target computer and connect to it from another device. Specific steps may vary depending on the software or settings used, but the general process is similar.
Step 1: Perpare the Remote Computer
Before leaving the computer you wish to control remotely, install your chosen remote access software and complete the initial setup.
Note that the computer requires a stable internet connection and must be configured to allow remote access. If you plan to connect to the computer regularly, it is recommended to enable the "unattended access" feature; this allows you to access the computer at any time without requiring manual approval for each connection request.
For example, using AweSun, you can configure a device for password-free remote control and then connect directly to it from another supported device.
Step 2: Install the Remote Access Software on Your Other Device
Next, install the same remote access application on the computer, tablet, or mobile phone you intend to use for the connection.
By using a cross-platform remote access tool like AweSun, you can access a Windows PC from a Mac, or connect to your computer via an Android or iOS device.
Step 3: Connect From a Different Network
You can now connect to a remote computer even if the two devices are on different Wi-Fi networks or internet connections.
Depending on the tool you are using, you can select a remote device from your account or manually enter the device ID and access credentials. For one-off connections—such as assisting someone with their computer—using a temporary password or access code is also very convenient.
Step 4: Start Controlling the Remote Computer
Once the connection is established, the remote computer's desktop will appear on your current device. You can then open applications, access documents, and perform various tasks just as if you were sitting right in front of that computer.
When you have finished, remember to end the remote session and disconnect from the computer.
How to Keep Remote Access Secure
Connecting to a computer over the internet is convenient, but it also means your remote session may pass through networks you do not fully control. A few basic precautions can help reduce unnecessary risks.
It is best to set a strong password for your remote access account and avoid sharing login credentials with others. We recommend enabling available authentication or access verification features and keeping your remote access software up to date.
When using remote access tools like AweSun, users can also leverage encrypted connections and access control features to secure remote sessions. If accessing your computer via a public or shared network, be sure to disconnect when you are finished.
These measures are not intended to complicate remote access, but rather to ensure that only authorized users can connect to your computer.
Can I remotely access a computer from my phone?
Yes. Many remote access tools support mobile devices, allowing you to connect to a configured computer from an Android or iOS device.
Can I access a Windows computer from a Mac?
Yes. Cross-platform remote access software, such as AweSun, allows a Mac to connect to and control a Windows computer.
Does the remote computer need to stay turned on?
In most cases, yes. The computer generally needs to remain powered on, connected to the internet, and available for remote access. If you need to turn the computer on remotely after it has been shut down, you can use AweSun's Q1 hardware in conjunction with the AweSun software to enable remote startup.
Can I remotely access my computer while traveling?
Yes. As long as the host computer remains available and both devices have an internet connection, you can establish a remote session from another location.
With the right remote access setup, you can control your computer from another location without being on the same network.
Try AweSun to get started with simple, cross-network remote PC access.
