Remote control is not only faster, but also safer! Awesun 16 Detailed Interpretation of the Whole Process Safety System
Safety remains the core proposition of Awesun 16, and as a first-line remote control brand, Aweray Awesun has always regarded safety as an unshakable cornerstone.
With the new launch of Awesun 16, the remote control experience once again ushered in a leap. The performance and function of the comprehensive upgrade, the first "super desktop", to achieve application integration to break through the boundaries of the device, while the remote control performance is greatly improved, the operation is smoother, the picture quality is clearer. In addition, safety remains the core proposition of Awesun 16, and as a first-line remote control brand, Aweray Awesun has always regarded safety as an unshakable cornerstone.
Instead of treating security only as a "bottom line indicator", the Awesun team has deeply studied and judged the differentiated requirements under various remote control scenarios, created a complete security strategy covering individuals and enterprises, and provided users with all-round protection from access to operation with a "full-process security closed loop" system.
Next, let's take a specific look at how Awesun shape this comprehensive remote control security system.
Aweray Awesun 16 takes the controlled end as the core to guard the safety of remote control
The core of the "whole process safety closed loop" system launched by Aweray Awesun is the "controlled end" in remote control ". Whether we need to accept or provide remote assistance to others, or we need to remotely control equipment that we are not around, the location of the accused end is closer to the center of privacy or confidential information, and is at the core of security.
Therefore, the Awesun safety closed-loop system is centered on the "controlled end. Awesun 16 is not only equipped with multiple security protection, users can also freely choose whether to allow others to remotely access the machine.
If we want to accept assistance from others, then the following functions can help us very well:
● Two-factor authentication access
We can turn on the "two-factor authentication access" function in the setting options. After turning on, each remote assistance initiated through the identification code requires your consent, even if the other party has the remote control verification code of your device.
● Set anti-harassment policies
We can set up a blacklist of IP addresses, or directly disable remote control of identification codes to prevent strangers from frequently sending remote control requests to you after learning your identification codes, thus preventing harassment.
    • ● Send alarm notification through WeChat public number
      In addition to Awesun software, it is now also supported to send the above alarm notification and remote control and file transfer records through the bound WeChat account. If we find some doubtful operations, we can immediately interrupt the remote control.
● The controlled end is in a dominant position in operation
In the process of receiving remote assistance, we are always in a dominant position in operation. We can prohibit the mouse operation and file transmission at the control end. If both the main and controlled parties are operating the mouse at the same time, the control right of the mouse belongs to the assisted party first, and we can prevent the main control end from implementing security-sensitive operations on you in time.
● Remote Control Record View
We can view detailed records of operations such as remote control and file transfer, which can also be sent to your Awesun software and bound WeChat through the notification function mentioned above, and support blackmailing the other party's account and risk reporting.
● Sensitive process list alarm
You can set a sensitive process list for software with high security level, such as financial software and company business systems. When these software are running during remote control, an alarm will be sent to you in time. If the behavior is not authorized by you, remote control can be interrupted immediately.
Aweray Awesun 16 Remote Control Self-use Equipment: Enhanced Privacy and Identity Protection
If we need to remotely control the equipment that belongs to us but is not around us, our security concerns mainly come from the privacy leakage that occurs at the scene of the accused equipment. In the face of this concern, Awesun also carry many security functions:
First of all, when deploying the login Awesun, we need to carry out [device login verification], that is, to verify the identity of the login, and at the same time, an alarm will be issued when logging in in different places to ensure that the login environment and identity are trusted.
In addition, when the Awesun initiates remote control of unattended equipment, it adopts the [double password protection] strategy, which can use the account password to double check the user name and password of the local system of the controlled end, further improving the security of the controlled end.
When we are remotely controlling our own devices, Awesun are also equipped with features that ensure the privacy and security of our information:
● Privacy screen
During the remote control process, if we are worried that others will inadvertently spy on the private information on our device through the screen of the accused end, we can turn on this function. After opening, the controlled end will display a black screen during remote control, and others will not be able to see your operation and screen information.
● Automatic client lock
We can set the interface that automatically locks the Awesun client to prevent others from viewing or modifying your controlled software settings.
● Automatic screen lock after being charged
When our remote control is over, your controlled computer is not out of our control. We can turn on the automatic screen lock function to make the controlled device automatically lock the screen after the remote control is over, so as to ensure that the remote device will not "run naked" at the safety level ".
Enterprise safety closed-loop system: prevention in advance-protection in the event-traceability after the event
At the enterprise remote control solution level, Aweray Awesun based on the application and implementation experience of remote control solutions from all walks of life, and also based on the security logic of "prevention in advance-guarding in the event-tracing after the event", to build a perfect and flexible security framework for enterprise remote control needs.
The security framework includes many practical and mature functions, such as pre-fine authorization, multi-factor security protection, watermark policy, software custom permissions, post-tracking log audit, hardware change records, and so on.
Enterprises can adjust the most appropriate overall security strategy according to their own needs, flexibly respond to the security needs of specific businesses, and realize independent, multi-scenario, multi-purpose security remote control.
Generally speaking, the safety of remote control is never dispensable, but the bottom line that must be adhered to for a long time. Awesun 16 in the performance and experience of continuous breakthrough at the same time, through the "whole process safety closed loop", to provide users with a full range of protection. It can be said that the Awesun security system is not only "holding the bottom line", but also "evolving in an all-round way". It makes remote control no longer just a convenient tool, but a reliable and reliable productivity base.
