Telecommuting enhances disaster tolerance, typhoon weather Aweray Awesun telecommuting solution insurance business
57
For enterprises, extreme weather events mean that employees can not commute, power interruption, network connection problems and IT system paralysis and other challenges, the traditional office model of key business functions may be completely stagnant, which requires enterprises to deploy professional remote office system in advance.
As a national-level remote control brand, Aweray Awesun provides enterprises with a professional remote office solution that can be quickly deployed, which greatly improves the disaster tolerance of enterprises in the face of extreme weather and realizes seamless business connection. Here we will take a look at this solution in detail.
Remote office rapid deployment, three steps to complete the system construction
One of the major features of the Aweray Awesun enterprise office solution is that the deployment process is extremely lightweight, which will not bring too much front-end cost to the enterprise. The construction of the remote office environment can be completed within a few hours, and the imminent threat of super typhoon can also be dealt with calmly. The deployment process of the whole scheme can be summarized in only three steps:
● Build organizational structure and create member accounts
● Customize and distribute software in batches
● Implement role permissions and authorize equipment
In the Awesun telecommuting system, employees have independent accounts and telecommuting does not interfere with each other. These accounts are under the management of super-managed accounts and can remotely access corresponding office equipment to form and build a multi-level enterprise organizational structure.
In addition, the scheme also supports docking with third-party IM accounts (enterprise micro, nailing and flying books), and employees can scan the code and log in with one key, thus realizing efficient integration with the existing system of the enterprise. After creating the organizational structure and specifying the member accounts, the administrator can customize the exclusive enterprise remote control installation package in the background of the Awesun, make corresponding adjustments to the software functions and appearance, and uniformly distribute the installation package after generating the installation package.
In terms of authorization management, the company's equipment can only be remotely controlled by the corresponding employee account number after being authorized. This authority can also be withdrawn by the administrator at any time when it is not needed to ensure that remote control is under the unified management of the enterprise.
In addition, enterprises also support different roles to grant different remote control function permissions, this function can help enterprises to regulate the specific behavior of different positions of personnel in remote office.
Efficient remote office and stable support
Awesun remote control provides efficient and stable services at the technical level. Self-developed SADDC algorithm realizes low delay, high smoothness and high frame rate picture transmission. Through visual saliency algorithm, network bandwidth occupation is greatly reduced without user perception. At the same time, Windows, macOS, iOS, Android, Linux and other systems are supported, and peripheral practical functions such as remote file, remote SSH/CMD and so on are carried, enough to cover the needs of the enterprise office.
At the hardware level, Aweray Awesun is also a rare brand in the industry that practices the strategy of integrating software and hardware. Its enterprise remote control scheme can be matched with many first-party hardware products to form a scheme matrix of combining software and hardware. For example, it can deploy Awesun intelligent startup devices such as startup stick/box, startup socket/patch board, etc., and can perform timing/countdown remote startup, batch startup/shutdown, etc, meet the office unattended case of remote boot demand, office stability without interruption.
Conclusion:
The typhoon transit is only a short day or two, but the loss of business suspension may be far-reaching. With the right telecommuting solution, enterprises can build a lifeline of business continuity in a disaster and ensure that enterprises can quickly resume normal operations after the storm. This is one of the core values that Awesun enterprise office solutions bring to enterprises in special weather.
As a national-level remote control brand, Aweray Awesun has been deeply engaged in the field of remote connection for 19 years. The remote scheme has been adopted by leading enterprises including Huawei, Vanke and Skyworth. China has more than 0.1 billion registered users, more than 1.2 million enterprise customers and more than 2 billion access devices. At the same time, Aweray Awesun and Shanghai Software Industry Association jointly released the first group standard for the remote control industry, it accelerates the application of remote control software technology in a wider range of scenarios in the future.
