How can severe weather enterprises improve their disaster recovery capabilities? It is important to have a fast remote control scheme.
603
This summer, there are especially many extreme weather, high temperature and typhoon rainstorm appear alternately, many enterprises will have to face the situation of suspension of production, the loss can not be underestimated.
In the face of this situation, enterprises urgently need to improve disaster recovery capabilities, and the deployment of a lightweight and professional remote control scheme is a reasonable choice.
As a national-level remote control brand, Aweray Awesun provides a professional remote control scheme for enterprises, enabling daily colleagues who work together in different places to improve the disaster tolerance of enterprises, and will not completely shut down their business even in bad weather.
When enterprises deploy remote control solutions, they often worry about whether the deployment cost is too high, whether the original organizational structure of the enterprise can be efficiently connected, and how stable the service is.
In the face of these pain points, Aweray Awesun programs have given relatively good answers. Next, we will introduce them in detail.
Lightweight deployment, "three steps" can be completed, put into use within a few hours
As a typical enterprise SaaS solution, the enterprise office solution provided by Aweray Awesun has the characteristics of lightweight, the deployment threshold is very low, and it can be completed in three steps, which greatly reduces the hidden cost investment in the early stage of the enterprise.
Specifically, first of all, enterprises need to build an organizational structure and create member accounts.
The second step is to customize and install remote control software in batches.
Finally, the equipment that needs remote control can be authorized and put into use.
In this process, many functions carried by Aweray Awesun can further empower enterprises and provide significant advantages.
Core advantage one: stable and advanced remote control service
Aweray Awesun remote control technology is quite mature, spanning Windows/macOS/Android/iOS/Linux multi-platform, self-developed SADDC and other algorithms to achieve extremely low remote control delay, while high-definition image quality, smooth frame number, color restoration, greatly improve the remote office experience, and thus improve business efficiency.
At the functional level, Awesun remote control covers the specific needs of different positions: including remote file transfer, dual-screen control, remote RDP, remote CMD/SSH commands, privacy screen, tablet mapping, etc.
Importantly, Aweray Awesun has also introduced many hardware devices used in conjunction with remote control, such as boot sockets/plug strips and boot sticks/boot boxes. These hardware can realize remote on and off, so that remote office is not subject to whether the station equipment is turned on or not, and the stability of office is not interrupted.
Core Advantage 2: Rapid Customization Deployment and Grouping
Support customized enterprise remote control installation package and implement rapid deployment. The customization process can make corresponding adjustments to the software functions and appearance, and after the installation package is generated, it can be uniformly distributed for employees to install.
In addition, the custom package supports the setting of grouping policies in advance, so that the corresponding custom package can automatically divide the devices into the specified groups after installation, and can also realize automatic grouping by allowing the system to detect whether the device name/comment name contains the specified keywords, thus greatly reducing the grouping management burden of the administrator after deployment.
Core Advantage 3: Employee Independent Account System
Enterprise employees have independent accounts, and remote office does not interfere with each other. These accounts are under the management of super-managed accounts and can remotely access corresponding office equipment.
Enterprises can configure the appropriate number of accounts when purchasing solutions based on the actual number of people needed, and build a multi-level enterprise organizational structure to meet business needs.
Core Advantage 4: Dockable to existing mature organizational structure
Support the docking of Awesun remote office solutions to various existing systems of the enterprise, and automatically synchronize with the existing organizational structure without manual construction.
Support docking with third-party IM accounts (enterprise micro, DingTalk, flying book), employees can scan the code and log in with one key; If the privatization deployment service is used, AD domain access is also supported.
Core advantage five: perfect authority management and authorization system
The Awesun solution supports granting different remote control function permissions to different roles. This function can help enterprises standardize the specific behaviors of personnel in different positions during remote office work.
In addition, at the equipment level, the company's equipment can only be remotely controlled by the corresponding employee account number after being authorized. This authority can also be withdrawn by the administrator at any time when it is not needed to ensure that the remote control is under the unified management of the enterprise.
Summary:
In the face of disaster recovery remote control scheme under extreme weather, lightweight, professionalism and stability are all important indicators, and Awesun remote control scheme is equipped with high-quality functions in these aspects, which can be said to be very suitable for enterprises. At present, including Huawei, Vanke, Skyworth and other head enterprises are using Awesun remote control scheme, enabling different business scenarios, continue to create value.
As a national-level remote control brand, Aweray Awesun, in conjunction with the Shanghai Software Industry Association, released the first group standard in the remote control industry, accelerating the application of remote control software technology in a wider range of scenarios in the future. Awesun parent company "Aweray" has been deeply engaged in the field of remote connection for 19 years, with more than 0.1 billion registered users, more than 1.2 million enterprise customers and more than 2 billion access devices.
