What to Do If Microsoft Remote Desktop Cannot Connect to Windows Home Edition
Ryan CarterRyan Carter
2026-09-01
Microsoft Remote Desktop isn't available on Windows Home as a host. Learn why RDP fails and how to remotely access a Windows Home PC with an alternative.
Microsoft Remote Desktop is a convenient way to remotely connect to Windows PCs, but Windows Home editions do not support incoming Remote Desktop host connections. If the remote PC is running Windows Home, you can use the Windows Home PC as a client to connect to other systems, but you cannot directly accept RDP connections on it.
To resolve this issue, you need to upgrade to Windows Pro or use third-party remote desktop software.
Why Microsoft Remote Desktop Doesn't Work on Windows Home
Microsoft's Remote Desktop feature requires a computer running Windows Professional, Enterprise, Education, or Windows Server. Windows Home can be used as a client device to connect to another supported computer, but it cannot act as a remote desktop host.
If your remote desktop is not working properly, the first thing to check is the Windows version of the computer you are trying to access.
You can check your Windows version by clicking "Settings" > "System" > "About," and then under "Windows Specification." If the version shows "Windows Home," the built-in Remote Desktop feature cannot be used as a host.
check Windows version
If you cannot connect to a computer using Microsoft's Remote Desktop because your computer is Windows Home, and repeatedly checking the computer name, changing connection settings, or troubleshooting network problems doesn't work, try using Awesun. This is a remote desktop software that is not limited by Windows version and can connect your various Windows versions or Macs to each other—stable, smooth, and without lag or disconnections.
How to Remote Access a Windows Home PC With AweSun
When you need to remotely control a Windows Home computer, AweSun offers an alternative. Instead of relying on Microsoft's Remote Desktop Hosting feature, AweSun uses its own remote access connection, so the computer being accessed is not limited by its Windows version.
The basic setup is straightforward:
1.Install AweSun on the Windows Home PC.
Download and install AweSun on the computer you want to control remotely.
2.Install AweSun on your other device.
You can use another Windows or macOS computer, or a supported Android or iOS device as the client.
3.Sign in and connect your devices.
Log in and configure the Windows Home PC for remote access. Once the computer is available, select it from the client device to start a remote session.
4.Control the Windows Home PC remotely.
After connecting, you can view and control the remote desktop, access applications and files, and perform tasks as if you were using the computer directly.
Windows Home remote desktop software
Awesun is incredibly helpful when your primary Windows Home desktop is left at home. You don't need to upgrade your operating system to enable Remote Desktop Protocol (RDP); simply leave your existing computer where it is and access it remotely when needed.
Microsoft Remote Desktop vs. an Alternative for Windows Home
The main difference is not necessarily about which tool has more features. It is about whether the remote computer meets the requirements for hosting a connection.
Function Microsoft Remote Desktop AweSun
Host OS Windows Home cannot act as an RDP host Supports Windows Home and other supported Windows/macOS systems.
Internet Access RDP can work over the internet, but accessing a PC from outside its local network requires additional configuration. Supports cross-network remote access without manual port forwarding.
Performance Designed primarily for desktop and productivity tasks. Supports up to 4K at 144 FPS for high-performance remote control.
Privacy Screen No built-in privacy screen Privacy Screen supported
AI & Automation No built-in AI remote-control capability. Supports AweSun MCP for AI-assisted remote control.
For someone whose primary PC runs Windows Home, this distinction is important. If you want to connect to RDP but discover that the Home Edition cannot act as the host, switching to a remote access solution may be simpler than changing the operating system.
When Should You Use a Microsoft RDP Alternative?
If your needs are limited to standard remote desktop access, then Microsoft Remote Desktop is a practical option. However, if your setup or use case doesn’t support Microsoft Remote Desktop, an alternative might be more convenient than upgrading your system.
Furthermore, the scenarios in which you use remote access might also prompt you to look for alternatives. You might need to provide remote assistance to family members, remotely play computer games while commuting, access applications installed on another computer, or remotely manage files and downloads. These tasks don’t necessarily require a full RDP setup, but they can certainly benefit from simpler, more flexible access methods.
Remote access software like AweSun comes in handy. In addition to simple remote control, it supports features such as file transfer, unattended access, and remote assistance, giving users more options when they need to go beyond the scope of a standard RDP connection.
Final Thoughts
If remote desktop not working on a Windows Home PC, the problem may not be your network or connection settings—the operating system edition itself may be the limitation.
If upgrading to Windows Pro is not what you need, an RDP alternative such as AweSun can provide a simpler way to access and control your existing Windows Home computer remotely.
Try AweSun to remotely access your Windows Home PC without relying on Microsoft's Remote Desktop host feature.
Do I need to upgrade Windows Home to Pro for remote access?
Not necessarily. Upgrading to Windows Pro is one option if you specifically want to use Microsoft's built-in Remote Desktop feature. Alternatively, third-party remote access software such as AweSun can allow you to remotely control a Windows Home PC without upgrading the operating system.
Why can I connect to some PCs but not my Windows Home computer?
The difference may be the Windows edition of the remote computer. A Windows Pro PC can host Microsoft's Remote Desktop connections, while Windows Home cannot. Check the Edition under Settings > System > About on the computer you want to access.
Can I access a Windows Home PC from a Mac or phone?
Yes, with a cross-platform remote access solution. AweSun supports access from Windows, macOS, Android, and iOS, so you can use a different type of device to connect to your Windows Home PC.
Can I still use Microsoft Remote Desktop on Windows 10?
After October 14, 2025, Microsoft will no longer provide free software updates, technical support, or security fixes for Windows 10 through Windows Update. Your PC will still function, but upgrading to Windows 11 is recommended. If you do not wish to upgrade, you can use Awesun to connect remotely.
Ryan Carter
Ryan CarterSystems Automation
