How to Control One PC From Another
Being able to control one PC from another can be useful in many situations. You may need to access a computer while working remotely, help a friend troubleshoot a problem, retrieve files from another PC, or manage multiple computers from one location.
There are several ways to control one PC from another. The best option depends on the devices you use, where the computers are located, and whether you need simple access or additional remote control features.
This guide looks at several common approaches, including built-in remote desktop tools, cloud-based remote access services, and third-party remote control software.
Why Control One PC From Another?
Remote control allows you to view and interact with another computer without being physically in front of it. Common use cases include:
- Remote work: Access files and applications on another computer.
- Remote support: Help a friend, family member, or colleague troubleshoot an issue.
- Device management: Manage computers located in different places.
- Collaboration: View or interact with a shared computer during a support or working session.
- File access: Open and manage files stored on another PC.
The right remote control method depends on your setup. Some users only need occasional access between Windows PCs, while others may need to connect across different devices or access a computer from another location.
Methods to Control One PC From Another
1. Built-In Remote Desktop Solutions
Many operating systems include built-in tools for remote access. On Windows, Remote Desktop allows you to connect to another compatible Windows PC using Remote Desktop Protocol (RDP).
How to Set Up Windows Remote Desktop
On the PC you want to control:
- Open Settings.
- Go to System > Remote Desktop.
- Turn on Remote Desktop.
- Make sure the user account you plan to use has permission to connect.
On the computer you are connecting from:
- Open Remote Desktop Connection.
- Enter the computer name or IP address of the remote PC.
- Enter the required account credentials.
- Connect to the remote desktop.
Advantages
- Built into supported versions of Windows.
- Useful for straightforward remote access.
- No separate remote control application is required.
Limitations
- The host PC must support incoming Remote Desktop connections.
- Connecting from outside the local network may require additional network configuration.
- Setup can be less convenient when you regularly switch between different devices and operating systems.
For users who only need occasional access to a compatible Windows PC, the built-in option may be enough. However, some remote access needs involve more devices, different platforms, or simpler connection management.
2. Cloud-Based Remote Control Services
Cloud-based remote access services provide another way to connect to computers over the internet. Instead of manually entering local network information each time, devices are typically linked through an online account or service.
One example is Chrome Remote Desktop, which allows users to configure remote access and connect through their Google account.
Advantages
- Generally straightforward to set up.
- Can be useful for accessing devices from different locations.
- Supports remote access across multiple platforms.
- Connection management is handled through an online service.
Limitations
- Features may be relatively basic compared with dedicated remote control software.
- You may need to use a specific account or ecosystem.
- Advanced remote management features may be limited depending on the service.
Cloud-based services can be a practical choice for users who mainly need simple remote access. If you need more control options, device management features, or different ways to establish remote sessions, a dedicated third-party remote control application may be more suitable.
3. Third-Party Remote Control Software
Third-party remote control software is designed specifically for remote access and remote assistance. These tools often provide additional features beyond basic screen access, such as unattended access, file transfer, device management, or support for multiple device types.
Popular options include TeamViewer, AnyDesk, and AweSun.
Using AweSun to Control One PC From Another
AweSun can be used to remotely control another authorized computer from supported Windows, macOS, Android, and iOS devices.
This can be useful if your remote access setup involves more than two Windows PCs. For example, you may want to access a Windows computer from a Mac, connect from a mobile device while traveling, or manage several personal devices through one account.
Depending on your access setup, you can connect to another computer using its device information and the required connection credentials. For devices you access regularly, unattended access can also allow you to connect without requiring someone to manually accept each session.
AweSun also supports features that can be useful during remote control, including:
- Cross-platform access: Connect between supported Windows, macOS, Android, and iOS devices.
- Unattended access: Access authorized computers when no one is physically present.
- Remote assistance: Connect to another computer when helping someone troubleshoot an issue.
- File transfer: Move files between supported devices during remote access.
- Encrypted connections: Help protect data transmitted during remote sessions.
These features can be particularly useful when remote access is part of your regular workflow rather than an occasional connection between two computers.
Best Practices for Secure Remote Control
Regardless of which method you use, remote access should be configured carefully.
- Use strong passwords: Avoid simple or reused passwords for accounts with remote access.
- Limit access: Only authorize users and devices that need to connect.
- Keep software updated: Install updates to receive security fixes and improvements.
- Protect connection credentials: Do not share device IDs, passwords, or access credentials publicly.
- Review device access: Remove devices or permissions that are no longer needed.
There is no single best way to control one PC from another. Built-in tools can work well for straightforward connections, while cloud-based services can simplify remote access across locations.
For users who need additional flexibility, such as cross-platform access, unattended connections, remote assistance, or file transfer, dedicated software such as AweSun provides another option.
The best choice depends on how often you need remote access, which devices you use, and what you need to do once connected.
How can I control one PC from another?
You can use a built-in remote desktop tool, a cloud-based remote access service, or third-party remote control software.
Do both computers need to use the same operating system?
No. Some remote control tools support connections across different operating systems and devices.
Can I control a Windows PC from a Mac or mobile device?
Yes. A cross-platform remote control tool such as AweSun can allow supported macOS, Android, or iOS devices to connect to a Windows PC.
Can I access my computer when nobody is there?
Yes. If unattended access is configured, you can connect to an authorized computer without someone manually accepting the connection.
Is it safe to control another PC remotely?
Remote access can be used securely when you use strong passwords, limit access permissions, keep software updated, and use trusted remote control software with encrypted connections.
